Hello All,
My issue is that the exterior door handle won't come out after removing the set screw. Is there something I am forgetting ? The set screw came out easy and the handle moves freely, but won't come out completely.
Become a Member!
You need to soak with penatrating oil. I have had to take the door panel off and I. Think I may have had to drill a small hole in the door so I could use a punch to tap on the handle shaft to get the handle out, just take your time and it will come out.
Much THX dens41. I will give it a shot.
Thx again, PB Blaster worked in seconds.
Glad it worked, sometimes we can not be in a hurry on the old stuff.
