Does anyone know how to remove the console cover on a '78 Corvett so I can access the heater fan switch to replace it?
I don't see any visible screws, and I don't just want to start prying on it without knowing how it is attached.
Wilwood Engineering1955-1957
You need to remove the two side panels that have carpet on them, there will be a screw back by the seat that can be a little hard to see. On e you have the sides off you should see the other screws that hold the panel down.
