kevin47 Offline OP
I guess it's been around awhile...I haven't heard of it before 'cause I live under a rock...I found it as I was looking for small engine fuel solutions...So far, the best I've found is SEF ( small engine fuel ) But at around $7 a quart I won't be using that stuff in my car...
But back to StarTron...Anyone using it...?
What is it supposed to do. I have not heard of it but then I reside under a bigger rock. talk
kevin47 Offline OP
It's claims are as follows: Makes engines start easily and run smoothly...removes & prevents gum, varnish and carbon...Stabilizes fuel; rejuvenates old fuel ( yeah, right )...Okay here's what grabs me..."Helps" prevent phase separation by dispersing water throughout fuel as submicron-sized droplets that are safely eliminated while the engine operates...
Can't help but wonder if it's just another scheme to separate me from my money...
...Cures & Prevents Ethanol Fuel Problems...Also says it improves gas mileage...
I did read some interesting reviews on it last night from marine/boater types...Some thought it might be a "notch" above "Stabl", but sounded a little inconclusive to me...
Last edited by kevin47; 07/21/12 12:03 PM. Reason: ...it costs more than "Stabl", too...
Kevin, just mixed-up a batch of Stabilize-it-all, add "some" to your gas and/or oil. Also great to rub on sore backs and joints, treats gout and athletes foot. Also good in fish and turkey frier's. Sent cash only to: wink
Really though, it probably does not hurt anything to use.
kevin47 Offline OP
I first noticed this product in this month's issue of Popular Mechanics...
I read somewhere that gas line anti freeze will prevent phase separation since that's what it does, absorb water in the gas.
kevin47 Offline OP
Wow... And it's a heck of a lot cheaper...!
Kevin....If it don't grow hair...I ain't buying it..Sorry>>>ED
kevin47 Offline OP
Hold on...Let me read the label again...
Last edited by kevin47; 07/21/12 04:54 PM. Reason: Nope...Sorry, Ed. Your out of luck...
