#248600 07/11/12 11:15 AM
jmstaff Offline OP
I timed my engine last night the timing mark on the flywheel looks like this A I thought the ball was the top dead center that you timed the car the engine runs fine does anyone have an answer do I have the distributor out 180 degrees?
You don't have the distributor out 180 deg. You use a timing light to time to the ball and it is not top dead center. The ball is advanced from top dead center.
