Posts: 7 |
I recently overhaul my 1928 engine and have a small leak beneath the distributor.
Has anyone run into this problem.
Thanks for any information.
I suggest you go to Tech Talk and scan through "School is in Session". Use the index to find the area of interest. This assumes you have a valid VCCA #
Posts: 1,213 Likes: 1
Posts: 1,213 Likes: 1 |
Could be a possible combination of the distributor housing being worn(the part of the distributor body that fits into the block should be 1 1/16" diameter),or the machined hole in the block is worn(it should be just a clearance fit for the distributor body), giving you your oil leak.
CJP'S 29
Also suggests pressure in the crankcase. Is the tube from front of engine behind the water pump attached to the inlet section of the carburetor? If so is the pipe and passage to it from the oil sump clear? If the crankcase is not properly vented then you will have oil leaking past the lifters, distributor and maybe front and rear crankshaft.
Posts: 221 |
I agree with Chipper, it sounds like pressure in the bottom-end, however, this is natural for hours after a rebuild because it takes time for the rings to fully seat. Assuming the rebuild included hone or bore and new rings. Run it for a few miles (100+) before digging into it.
PS I wish I could take my own advice, I would be taking it apart already!
