#247870 07/04/12 02:34 PM
I am in the process of restoring the gas tank on my 1950 Chevy, the sending unit which worked fine before seems stiff when I work the arm up and down. Does it pay to have this rebuilt or are the current reproductions a good way to go?
It may be full of crud from old gas, you might want to try soaking the business end of the sending unit in something like Seafoam
Great idea, all I have to do is grind the heads of the two rivets off that secure it to the cap that bolts to the tank, I can alwaus refasted in with a couple of 6-32 screws. It may be a few weeks before I get a chance to do it but I will keep you posted, thanks Gary
I, too had a sending unit that after removal I noticed it was "stiff"...But I took it out back behind the shop to see how fur I could chuck it...I just didn't want to have to remove the tank a second time down the road...Got a new one off ebay for $50 bucks...I saved the old cork float for Halloween...
Kevin.....Why did you have to remove the tank to replace the sending unit??????ED
BTW don't OD on the burnt cork.
