#247708 07/02/12 11:36 PM
During my rewire, hooking up the turn signal I took off the top cover and there was a pile of metal shavings in it. Looks like when it was installed they put it up against the bottom of the steering wheel where it rubbed and wore a groove in it. When I hooked it up it didn't work. so I have ordered another one that should be here by the end of the week. Cannot figure out why they would install it that way.
It's know telling why.I remember my 41 ton 1/2 that it had the type that had a rubber wheel up against the steering wheel that when you turned the steering wheel it would cancel the signal.I miss that ole truck.
