#246791 06/24/12 04:54 PM
Tu papa Offline OP
Is there a special nut to attach the 1929 Headlight Stantions to the apron? Becasue of the location of the nut,using a conventional nut is hell to work with and just about impossible. Thanks for the help.
David Nittler
Tu papa #246816 06/24/12 09:10 PM
On my 30, it's a slotted screw. I used stainless steel.
karl
Tu papa #246843 06/25/12 02:30 AM
What he is looking for is a u shaped nut clip that fits over the edge of the frame rail. There are two for each side that the screw threads into to hold down the stanchion ferule. They are about 1-3/4" long and I think have a 1/4" nut welded to the bottom side. The front splash apron covers all of this making it difficult to get a regular nut in there.
Tu papa Offline OP
Thanks, where do you find these?
David Nittler
Tu papa #246857 06/25/12 09:28 AM
Assuming they are similar to those clips used in '31, I will post pic first chance I get, they would be relatively easy to make in a shop with basic spot welding gear.
Tu papa Offline OP
Thanks, I'll be looking.
David Nittler
They're available from Restoration Specialties & Supply in Windber, PA. Look here:
http://www.restorationspecialties.com/Catalog-PDF.html
All the Best, Chip
"It's wise to choose a SIX"
Tu papa #247023 06/26/12 01:54 PM
I have posted a photo left of the clips used on '31's to hold fender in place. May be same/similar to what you need? Easy to make from 1/16" stock if you have a 1/4" tap set, no welding needed.
Chip #247044 06/26/12 05:35 PM
Tu papa Offline OP
Thanks chip, What do you call these nuts so I can look in the catalog? Thanks Dave
David Nittler
Tu papa Offline OP
Thanks Gunsmoke, How do I find the photo? Dave
David Nittler
Tu papa #247047 06/26/12 05:53 PM
Look in "VCCA Member's Photos", the column on the left side of the posts.
Chipper #247086 06/26/12 10:51 PM
David, it's "Extruded U-Nuts", P/N 10052, on Page 218 of the catalogue. The fastener is an oval head slotted screw, 5/16-18 x 1" long, available in stainless steel from McMaster-Carr or from the stainless fastener vendors at most of the major swap meets, or from me for multiple adult beverages.
Hope that helps.
All the Best, Chip
Chip #247148 06/27/12 04:58 PM
Tu papa Offline OP
Thanks. I ordered them from the catalog.
David Nittler
Tu papa #247179 06/27/12 08:27 PM
Darn. Guess I'll have to by my own next round.
Good luck with it.
All the Best, Chip
Chip #247223 06/28/12 07:30 AM
Tu papa Offline OP
Oh well.
David Nittler
Chip #247291 06/28/12 10:08 PM
Hey Chip, as a matter of interest.... is that fastener (the one for the candlestick) the same as the one used to hold in the dashboard panel?
Andrew
While the rest of the crew may be in the same predicament, it's almost always the pilot's job to arrive at the crash site first.
Skidd #247327 06/29/12 07:40 AM
Tu papa Offline OP
I used a regular nut. It is interesting to reach up behind do do the job.
David Nittler
Skidd #247471 06/30/12 05:13 PM
I believe the screws for the dashboard are slotted oven head screws rather than round head............
But I don't have my parts book at hand at the moment.
All the Best, Chip
