#245386 06/11/12 06:53 PM
lilrobo Offline OP
i am working on my dash lights
everything works fine but the dash lights , what i found out is when i touch a hot wire to the bottom fuse which is inst lights they come on with using the the headlight switch ,, so that means that the headlight switch when used in the dash light position send power to the fuse panel then goes to the dash lights ?????? does this make sense ???
Wilwood Engineering1955-1957
lilrobo #245387 06/11/12 07:36 PM
lilrobo Offline OP
yeah i do believe the switch is bad , i done some testing and the little spring is loosing connection from 1 end to the other
so i guess the ordering will begin
lilrobo #246756 06/24/12 08:17 AM
Headlight switches are really simple to clean up and repair. This is one from a Corvair. A little light sandpaper and I recommend a slight coating of conductive grease (available at Lowes or many other places)
[Linked Image from widman.biz]
More detail on it at this link
Headlight switch repair
