#246489 06/21/12 07:29 PM
Budd Offline OP
I have leaky brake wheel cylinders on my 1938 coupe. I have honed the cylinders and installed new kits but they still leak. Does anyone have an idea for a fix to this problem or do I need to purchase new cylinders. A few years ago I remember seeing an ad by someone who installed stainless steel inserts on cylinders but I don't have contact information now on anyone providing that service. Thanks Budd
Become a Member!
DFC Offline
Budd, If after honing you can see any rust etched indentions in the cylinder bore the new kit won't seal up. I gave up years ago and now send mine to Apple Hydraulics in New Jersey or White Post restorations in N. Carolina where they insert a stainless sleeve and will put fresh springs, seals and cups if you pay extra. They arenot cheap but whats your life worth? I have never skimped on brake maintenence and never had a failure. Takes about 2-3 weeks to get 'em back.
DFC
Budd...Welcome aboard.....Maybe you have honed the cylinders too much...and you should replace the rubber cups. They are available at any Napa store as well as the cylinders.
I thinks the rubber cups 1"..but ask them. They are cheaper at Napa and you don't have to pay postage.
If you want to replace the wheel cylinders the Napa # for both rear is the same #3396...
On the front, the left & right are different...
Left Napa # 3731...Right Napa #3730
You might want to replace the bleeder screws as well because you can't get a bleeder hose to fit on the old small bleeder screw...The Napa # for these bleeders screws (all 4 the same )is 6858.....Btw You might want to replace the brake hoses while you are at it Napa has them also..... GOOD Luck ED
The cylinders are 1 in on the rear and 1 1/4 on the front.
Budd WELCOME to the VCCA Chevy Chatter web site.
Welcome to Chatter
I would not bother honing a wheel or master cylinder as I have not been able to get honing stone fine enough for a reliable seal.
Either get new cylinders which by all indications are reasonably readily available or get your existing cylinders professionally resleeved with stainless.
Budd Offline OP
DFC
Thank you so much for your input. It is great to have the name of a supplier if I decide to go with stainless inserts.
Budd
Budd Offline OP
Ed 1938
Thank you so much for your input. I will contact NAPA and inquire about new wheel cylinders and thanks about the info on new bleeder screws. It is frustrating that a bleeder hose doesn't fit the old bleeder screws.
Budd
Originally Posted by tonyw
Welcome to Chatter
I was going to mention that last night...you can hone and hone and a lot of times it's just a waste of time...You never really know how deep the corrosion has "etched" in to the iron...I've even bored out .010" on a lathe and they didn't "clean-up"...I just ruined them...Now, the bores to big...I just toss'em and start fresh...Saves time...
If you have the time I highly suggest you send your cylinders for relining with brass or stainless. The new cylinders will corrode very soon on a car that is not used daily. This will not happen with the reline. You can purchase the kits from any parts store for a reasonable cost. This is as close as you can get to a permanent brake job.
devil Agrin
I assume you mean you can buy re-build kits for your wheel cylinders...and send out the cylinders for relining...I haven't actually seen "reline" kits, but wouldn't that be nice...
You are correct, that was not really clear. So, relining was one step and then purchase the cylinder kits from your local parts house.
devil Agrin
