#246235 06/19/12 10:50 AM
Rivard Offline OP
I am remaking the wood and ran into this.The front uprights hook to the top rails with a long bolt. Why. Is this to adjust the top alignment for the windshild. Can I just glue and screw the joint together without hurting something later. Thanks Paul
Rivard #246449 06/21/12 10:03 AM
Hi Rivard,
I have the cowl and dash metal off my car. I think you are talking about the long bolt in the corner that runs from the top iron down at an angle and ends with the triangular block. I see this as an important feature that pulls the joint together while distributing the forces from the windshield into the wood frame. Remember the force appllied to the windshield at the blazing speed of 25 MPH is substantial. I would not vary from the original design.
Kevin
490k #246532 06/22/12 03:36 AM
Just a comment to the wind pressure on the front screen when trailing a Four-Ninety in around 70 km/h (45 miles) on an open trailer:
Loosen the nuts on each side of the wind screen and turn the two halves nearly horizontal, but somewhat lower in the front. Then you will have no danger to destroy the connection between the frame and the torpedo.
I am repairing the roof of my youngest son these days, so I cannot promise pictures before the weekend.
parking
Solan G, # 32797
Solan #246698 06/23/12 03:15 PM
Here are the pictures of the angle positions I use when trailing Solan:
http://s889.photobucket.com/albums/ac98/solan1916/solan%201916%20front%20window/
Start with lowest picture number. (# 775)
Agrin
Solan G, # 32797
490k #246869 06/25/12 10:48 AM
Rivard Offline OP
I would love to see a picture of the front triangle piece. I am trying to figure out the correct way to fasten the front pillar to the top. Mine is rotted about an inch and a half, so I'm working with very little. The long bolt is there but I can't figure out if I am missing other parts to make it work. Thanks for any help
Rivard #247555 07/01/12 10:40 AM
I will take some pictures and try to post them.
Kevin
490k #247640 07/02/12 11:52 AM
Rivard Offline OP
Thanks for taking a picture. The nut is behind the top hingde of the door. I was told a hole was drilled from the top piece into the pillar and a square hole was made for the nut, to tighten the top to the pillar. Makes sence but I would rather do things right the first time. Thanks for all the help. Paul
