#240072 04/16/12 11:38 PM
Can,t seem to get the horn to blow on my 48 fleetmaster,,backed out the rubber screws, flipped metal ring over still no contact
works when jumpered.. any tricks to proper assembly..
truckguy #245867 06/16/12 12:42 AM
truckguy #245869 06/16/12 12:52 AM
I fixed mine recently, I had to replace the rubber pad ( 2.816 ) to make mine work...Is your pad okay...?
truckguy #246203 06/18/12 11:13 PM
good to see my post moved up..new pad do u know where the horn ring makes ground to honk .. i restored the wheel maybe when the horn ring hits the trim rings to make ground .. yea think
truckguy #246214 06/19/12 12:23 AM
Trim rings...You mean the trim moulding...? I thought it had something to with the spring and cups...You have the "cups" in place where they should be...? There also that threaded ring under the wheel on the column you have to adjust...The only problem I remember having was screwing the two rubber "plugs" down too tight and the horn ring wouldn't "ground"...
