#245681 06/14/12 12:01 PM
vukie Offline OP
Hi guys dose anyone have and idea what a running in mint condition 1933
194 six chevy engine is worth????? \\\
thanks J vukovich
vukie #245690 06/14/12 12:55 PM
I've bought complete drive trains from people building hot rods for 1,500.00 or less. This is engine, trans, front end, rear end, wheels & tires, bumpers, radiator, springs, gauges..etc. You'll have to break it down from there...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
jiaccino #245977 06/16/12 09:45 PM
Last August at the Arco Arena I bought a 33 master complete under carriage (less frame) with brake lines, 207 cu in. $500.00 and he delivered to my home in Tracy.
vukie #246611 06/22/12 09:47 PM
Hi Dale James. I need a good '33 master cylinder head. Would you be willing to part with the head from your '33 engine? I'm in San Luis Obispo, CA. Info@bridgecreekinn.com. Gene
Krugerbenz #246691 06/23/12 01:27 PM
Hi Gene
The reason I bought the stuff was mainly for the head. The one in my car now has been repaired and has some weld beads that show but are not obvious. if you look at it for a while they are evident. I also have another 33 in my sights to purchase a little down the road and want to hold on to this stuff for a bit to make sure I don't need it. I have seen a couple heads / engines since then at swap meets, send me a PM with a cell phone and I will give you a call when I see another one. I go to a lot of swap meets.
