#245361 06/11/12 12:02 PM
Mike33 Offline OP
What oil should I use to fill my transmission?Also,do I fill it until it runs out of the fill hole on the left side of the trans?Also is there a substitute for the oil sold by the Filling Station?I have a show to go to and I don't have enough time to order from them.Thanks in advance,Mike
What does your owner's manual recommend?
All auto parts and Wallmart carry 90/140 transmision oil. This will work fine in a standard trans.
Fill to the bottom of the fill plug on the side.
If I remember right the 32 and 34 owers manual calls for 190w oil, 90/140 will work but shifting will be harder then it should be. You should really be using 600w which is really 190w from what I understand. Some time in 31 or 32 they changed how they called out oil weight.
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
