Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
I saw this for sale on ebay , and was wondering if it is a 1931 lug wrench. it is dimensioned in the pictures. 1931 wheel nuts measure 3/4" and this is listed as 13/16" but may be worn larger at the socket end. item number 360464053637 ebay link
JACK
Posts: 301 |
G'day Jack, that looks like the ones I have I will email you a photo and dimensions tonight.
"Never give up" Louis Chevrolet
JACK
Posts: 44 |
Hi Jack & Micheal, It looks like the one that came with my '31, but does nut fit my wheel nuts which are 3/4" AF.
Cheers, Alan
Yes , as i said above it is a 13/16" socket end which is normally a ford wheel nut size, Model A, etc
JACK
Just for everyones information, the 1931 parts list has the *wrench, wire wheel hub nut," as part number 348905 .
JACK
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
The wrench on Ebay is not the 31 Wire Wheel Nut Wrench. That wrench looks like the crank and lug wrench. The Wire Wheel Lug Wrench looks like a speed wrench of a socket wrench set. On the end oposit the socket it looks like a screw driver for removing the hub cap.
Joined VCCA June 1, 1961
Thanks everyone, and thanks Back Roads for the proper description of the tool i am seeking.
JACK
