#24495 08/11/02 10:25 AM
I know it will not be original but....
My '37 will need lot's of wiring work done. I do not feel safe having it in the garage anymore with the risk of a fire. Anyone know what the labor should cost to have a new harness put in the entire car with the fuse block on it? Thanks, Alan
#24496 08/13/02 09:38 PM
A harness from YNZ's out of California will run around $400.00 plus a good day or so labor. There are two or three wiring companies listed in Hemmings. It might not be a bad idea to disconnect the battery when the car is parked.
