Agree with the Dog.Elecrical current interuption/reconnection has no ill affect on these clocks.They are not very complicated.Usually it's things like dust/dirt or windings just weaken over time.
The clock on '70 B-cars comes out through the rear/backside of dash.
I've done clock change outs on both my 70's numerous times.One air car one non-air.
If your Caprice is an A/C car,you may want to try going through the top of the dash! The dash pad is held on by approx 8-10 screws,then slides forward and off.The clock is clearly visable now with alot of light coming through to aid in change out.It's only 2 small 1/4" bolt head srews that hold it in.I've done it from under the dash like the Dog,and agree 100%,it's easier to do it on your back reaching up than to remove the dash cluster assembly.The clock is just above the radio.I've done it that way too by removing the radio from underneath,then it's like wide open spaces to access the clock!
The chrome knob on the front stalk is the easiest part of the job.Simply use a small jewelers flat blade screwdriver to remove the small set screw,while holding the actual chrome knob with the other hand.
I always unplug the clock at the fuse block.It's an orange accessory wire plugged into the center of the fuse block.
Hope this helps,Jim
