#2441 08/20/02 10:36 PM
CHEVY Offline OP
WELL HERE IS A SUBJECT THAT MIGHT BE INTERESTING TO ALOT OF CHEVY PEOPLE. WHILE ON TOUR IN JULY IN VICTORIA CANADA, MY COIL GAVE OUT. THE 32 COIL WAS A ORIGINAL ONE AND WAS IN WORKING CONDITION UP TO THE BREAK DOWN WHILE WE WERE ON OUR SATURDAY TOUR. THE DAY BEFORE WE TOURED ABOUT 100 MILES AND HAD NO PROBLEMS. WHEN I BROKE DOWN, THE FIRST PROBLEM WAS THE PLUGGED CARB FROM THE FUEL PUMP CORK GASKET. JUST BEFORE WE LEFT FOR THE MEET I HAD SET THE C-86 SPARK PLUGS TO 45 FOR THE GAP, BECAUSE OF TODAYS GASOLINE, :) :) chevy WHAT I WAS WONDERING IS, WITH THE PLUGS BEING HOTTER WITH A BIGGER SPARK, COULD THAT HAVE MADE THE COIL GET ALOT HOTTER AND THEN JUST QUIT WORKING?????? :) :) chevy chevy
#2442 08/20/02 10:54 PM
I would't think so.It was just its "time"
#2443 08/21/02 11:43 AM
CHEVY Offline OP
what is the best way to check a coil out. thanks :) :) chevy chevy :) :)
#2444 08/21/02 11:46 AM
The best way to test a coil is with a coil tester. This machine will test the coil both cold and hot and it will rate the coil as to how good it is. laugh laugh laugh laugh
#2445 08/21/02 11:53 AM
CHEVY Offline OP
THANKS FOR THE INFORMATION SKIP, I STILL HAVE PLANS TO GET MY COIL THAT QUIT WORKING, REBUILT WITH THE NEW INSIDES, BUT FIRST I HAVE TO GET THE ENGINE PROBLEM FIXED. THE GUY WHO REBUILDS COILS FOR THE PACKARD PEOPLE, WANTS ME TO BRING THE CHEVY TO HIS HOUSE SO HE CAN LOOK AT IT. MARC AT THE MACHINE SHOP SAYS DONT GO UNLESS YOU BRING THE CAR, AS THE GUY IS KIND OF DIFFERENT? :) :) chevy chevy :) :)
#2446 08/21/02 02:38 PM
Sounds like he is a Ford dude! :eek: :eek: laugh laugh laugh laugh
#2447 08/21/02 08:26 PM
Donald, after you use the Coil Tester, Got one in your hip pocket?
Then to see it will really work ok put it on a car and drive it around for a couple of hours. Then, when you have two good ones use the spare to test the system and the other car! YEAH!
#2448 08/21/02 08:56 PM
CHEVY Offline OP
HEY MR MACK, WHEN YOU SAY, WHEN YOU HAVE TWO GOOD ONES, IM LIKE THE JUNKYARD DOG AND START THINKING ABOUT A COLD BEER, BUT THE DOG HE DOES NOT LIKE BEER VERY MUCH, UNLESS IT IS KEG SIZE? :arrow: :arrow: :arrow: :arrow: bigl bigl
#2449 08/21/02 09:36 PM
Hey......the JYD has priorities! Elvira.......cold beer.......and Chevys.....in that order!! Of course, if you stop and think about it....they kinda sorta all go together. You know....you go in the Chevy.....the cold beer goes in your belly.......and Elvira goes in the back seat. And then......you go in the back seat with her! Ya!! Hey, it works for this mutt!!! :eek: :eek: dance dance dance dance dance
#2450 08/21/02 11:03 PM
Donald all you have to do is go down to NAPA and tell them you need a coil and a condenser for a 54 chevy car or truck and then in a couple of days it will be there. That will make you a good touring coil, then just change it out with the $200 rebuilt original coil for the "Big Show" also any Chevrolet coil on a Chevy with the ignition ballast resistor mounted on the firewall should work, I interchanged the one on my 1957 truck with the 53, and it ran.
#2451 08/21/02 11:06 PM
CHEVY Offline OP
THANKS MR MACK FOR THE INFORMATION, I WILL CHECK WITH NAPA. :) :) :) chevy chevy :) :) :)
#2452 09/08/02 09:55 AM
I am hearing a lot of talk about original coils. What do they look like? I have a coil that I was told is for a Chevy but am not sure if that is true. Check out these links to see some pictures of it and maybe somebody can let me know just what I have.
Thanks,
Paul
http://image.inkfrog.com/pix/junkyard4/Coil01.JPG
http://image.inkfrog.com/pix/junkyard4/Coil02.JPG
#2453 09/08/02 11:08 AM
Coil # 1 is a '41-46. Don't know about the other one.
#2454 09/08/02 10:40 PM
The pictures are of the same coil just diffrent ends.
Paul
