Posts: 83 |
Whats the proper tire pressure for my 28's tire with solid rims? Nothing listed on the tire. I have 32 psi but they look low. And I dont want to over inflate.
Posts: 558 |
Hi etnfrd67, According to the '28 Manual, passenger car tire pressure should be "...at least 35 pounds." 35 psi is what I'm using in my '30 coupe. http://chevy.oldcarmanualproject.com/chevyowner/28cim09.htmHappy Motoring, Dan
Posts: 37 |
Gooday Dan R, I have experimented with different pressures but have run my tyres on the 27 Chev utility at 36 lbs all round for several years and there seems to be no adverse wear signs or handling problems . I try and keep to bitumen roads as the dirt roads make for a lively drive. Check the max tyre pressure on the sidewall best not to exceed that.
Posts: 37 |
sorry response should have been addressed to etn frd67
Posts: 11,162 |
my 28 drives better with 40 PS! all the way around
Many eons ago when I worked at a service station the pressure we put into most of the cars with balloon tires was 32 psi. MrMack's recommendation has merit. At some point you start trading off the quality of the ride to better operation.
Posts: 1,284 |
I run on the high side of 35
Cheers
Ray
Posts: 83 |
I will have to find my cars happy place for air.
