Posts: 24 |
can anyone tell me the correct attaching hardware that attaches the bracket on the draft tube to the oil pan
Posts: 1,294 |
I don't quit understand the question. The bracket is spot welded to the pipe and it bolts on down at the pan. I have a spare draft tube if you need one.
Posts: 24 |
does the bracket bolt below the flange on the block or do you use a longer screw that goes threw the flange with a square nut on top
