Posts: 151 |
These numbers are cast into the block on the right side by the fuel pump.The first number may be wrong (bad casting). #336573.What does it mean?
kerry j camp
Posts: 558 |
Hi kc1952, If the first number on the casting is an 8 (and not a 3), then it indicates the block for a 194cid, 3 main, 1932 motor. http://home.znet.com/c1937/Cast.htmHappy Motoring, Dan
Posts: 1,966 |
It should also have a date stamped into it to confirm day/month/year of manufacture, typically something like B 16 2 which means February 16th 1932.
