#242960 05/15/12 11:47 AM
Does anyone know if there's a place that will recoat a steering wheel? I just bought a 37 Pontiac Deluxe 8 Touring Sedan and the rubber on the wheel itself is gone. The metal looks great and would like to use it if possible. Thanks. AJ
Here's a couple I pulled out of Hemmings Motor News........
J.B. Donaldson Co.
www.steeringwheelsusa.com
I've heard good comments on this one
www.KochsSteeringWheels.com
There's a bunch more in Hemmings. You should pick up a copy.
Good Luck with your project.
ken48
VCCA 42589
Thanks Ken48!
I have used Koch with excellent, concours quality, results. So, I can vouch for their service.
Other vendors of like services may be just a competent and produce similar results at a competitive price, as well.
Good luck,
Thanks Charlie!
Is there a diagram showing all the parts that go under the horn ring on the assy butterfly steering wheel to make the horn blow?? There is nothing under my horn ring just 3 screws that hold it to the wheel. Thanks, Phill
Phill #244183 05/30/12 05:54 PM
My steering wheel is on a '51 Chevy. Phill
