#221579 10/13/11 09:01 PM
6wheel Offline OP
My friend is restoring a '59 Impala Sport Coupe and wants to mount dual antennas on the rear fins. Can someone provide measurements for locating the antennas? We would need to know the distance from the back of each fin to the antenna hole, and the distance from the trunk opening to the antenna hole.
Thanks,
Sid
Wilwood Engineering1955-1957
Hi Sid,
I've seen people use different areas on the rear panels for antennas. I have a 1960 Convertible and mine is set 3/4" away from the trunk/quarter-panel divide, and 3" back from trunk/body divide. The exact distance is not as important as each antenna being uniform on either side. Also, just one antenna needs to be wired. The other is referred to as a "dummy" antenna and is basically just for looks.
I have a problem with my outside mirrors, in that I can't see out the passenger side unless I slide way over. I've seen some of these mounted parallel to the vent windows to avoid this problem. I've also seen them mounted on the back end of front fenders... which I didn't care for.
Good luck with the resto job.
Rich
"Of all the gin joints in all the towns in all the world... she walks into mine"
