blueyAU Offline OP
Hi there,
Because of the extreme cost involved, I am now thinking of having a go at doing the interior of my 34 chev std 4 door sedan.
One of the most baffling parts to me is how was the shape of the rear curved corners was obtained? Its a compound curve and I imagine some type of mould was made and then covered with material?
Another is the curve of the rear wheel arch where the doors open at.
Any interior pictures would be of great assistance..
Peter
never give 100% unless you are giving blood.
Peter,
I installed a Hampton interior kit on my '34 coupe. The corners are not a compound curve as you might think. They came flat in a box with material loosely attached. To install they are tacked to the wood frame. They were the hardest part of the install to get the material pulled and tacked tightly without wrinkles.
1934 Three Window Coupe
[img]http://www.youngsdecks.com/YoungsDecks/1934_Chevy.html[/img]
blueyAU Offline OP
Gday young F,
can you show me?
do you have any pictures of the event?
Peter
Hi Peter,
Here's some photos or the inside rear of two coupes (one restored and one original)& two sedans. The gray sedan is in NZ so possibly a Holden. Hope these help.
blueyAU Offline OP
hi there Pat,
thanks for the pictures.
mine, a standard , does not have a rear parcel shelve, but I get the general idea of how it goes.
They look totally wonderful, but I am not sure if I could ever get mine looking so neat and trim.
what looks like a simple job, may well turn into an nightmare and a total cock up...?
anyway I'm going to do test pieces to see what the end results are before committing to the real and expensive stuff for the interior!
thanks again for the pix, great stuff mate..
Peter
blueyAU Offline OP
Hi there All,
this is for the Australian guys in here.
I have been searching the web trying to find an Australian supplier of motor trimming supplies.
to date I have not had any success!
Does anyone know of a good comprehensive supply site site that will sell the the general public.
My local trimmer seems rather reluctant to give me any information or assistance..... stressed
Daleys Motor trimmer's supplies.
villawood. 9794 5700
http://www.daleys.com.au/products
JACK
Much appreciated Jack.
A very handy link
Cheers
Ray
blueyAU Offline OP
hi young falcon,
concerning the curved corners:-
you say the material was loosely attached, was it attached to some pliable board or cardboard?
and was it sewn at the edges to the cardboard or other and had long loose sides for tacking to the timber?
I'm just trying to visualise what was used...
front seat covering:-
was the rear of the front seat covered with a padded material, and was carpet used at the lower extremities?
any pictures would be of great help too..
Peter
Peter,
As near as my wife (who helped with the install) and I can recall, the material was glued to just one edge of the poster board like backing. I think it was the top edge.
We first tacked the piece at the top starting at one end and bending them as we tacked. We then moved to the bottom and did the same. It took some effort to get all the wrinkles out of the material but eventually we did. The material was folded around the two vertical sides and tacked. We did not use any further adhesive as the material stretched tightly when tacked and did not seem to require it.
I hope this makes sense and is helpful. I will try to email you some pictures of my interior to give you a better idea of what it looks like. It is a 3 window coupe so there is only a vinyl shelf behind the seat. The back of the seat is not finished except it is covered with black "poster board" and open to the trunk area.
blueyAU Offline OP
hi there young falcon,
thanks for the info, and look froward to some pictures..
Peter
Glad to help Ray, glad you appreciated it.
JACK
Peter,
If you would PM me your email I will send some interior pics of my '34 coupe.
blueyAU Offline OP
Hi there Jerry,
thanks for the pictures, your interior looks most professional, the curved corners look so smooth. Maybe you should take up auto upholstery in the long winter months? wink
regards
Peter
Peter,
I think, if any credit is due, it should go mostly to my wife. She is much more patient than I and kept us going at a pace that allowed us to do the best job we were capable of. Except for the usual "could you hold this" help the interior was the only thing she was heavily involved in.
You know you have a good marriage when the two of you complete the interior, together, of a three window coupe with no arguments.
