#241655 05/01/12 08:25 PM
I know it has been mentioned before but i did a search and couldn't find any thing here, if I go to my local brake shop what sort of material should I ask for? and what are the proper sizes for a '28, front rear and hand brake, RAY
Hi Ray,
Soft woven linings are needed for mechanical brakes. Here is a link to a similar question from a few years back:
https://vccachat.org/ubbthreads.php/ubb/showflat/Number/138909/Searchpage/1/Main/20208
Happy Motoring,
Dan
Thanks Dan just what i was looking for I searched for brake lining and nothing came up, data was the key word. RAY
I had the brake linings replaced at a truck shop with 3/16 webbing two years ago they work great. Hutch
Listen to the "click'n" of those push rods
Hey Hutch do you remember the name or the material used some woven modern stuff is not so good for steel drums,RAY
Ray, I am not positive but I think it was a cotten and fiberglass blend of some type. It was stiff but not hard. It was used on parking brake mounted on the drive shaft of some older trucks. Hope this helps. Hutch
