thanks mike very helpful.. get my horn to work at the steering wheel will be road ready..
Truckguy: I have a 48 as well. My wiper motor and switch aren't made like this. The "switch" on my car is actually a vacuum valve with 3 ports. The line coming from the intake manifold goes to one port and a line goes from the valve to the wiper motor. The knob you see in his picture looks like my dash knob - but my knob turns the valve, instead of mechanical linkage connected to the wiper motor. Have seen these valves occasionally on Ebay.
Regards;
Oldengineer
Hi truckguy,
I was waiting on some wiper parts to arrive in the mail (also a 48 Fleetmaster) when you first posted.
These pictures below (or links) are the Trico unit and switch that I found under the dash but I don't know if it's a 1947-48 Chevy unit, a replacement unit or not.
Hopefully someone here can confirm what it is.
Unknown to me, when I first attempted turning on the wipers, it was moving the wiper blades even though there were no pivot bushings or retainer installed.
With some luck, it will be moving them a little better with 'all' the parts installed.
The switch (shown on the right) has two different diameter vacuum hoses running to motor.
The empty port in the middle was where the hose from the manifold connected.
However, this switch rotates to the left to turn on the wipers, not to the right per the owner's manual.
I broke my first repo switch knob turning it to the right.
(Mike's knob might be factory or NOS - much nicer looking than the repro)
The mounting hardware (just right of the switch) seems to be:
Two slotted machine screws with star washers that goes into threaded sleeves.
A stepped rubber bushing (not shown - don't have them) goes through the pump mounting holes from the top -
- the sleeve through the bushing from the top -
- and the machine screw with star washer goes in from the bottom.
The rubber bushing and hex head sleeve probably acts as a lock washer once tighten.
If I can't find the bushings - two very short pieces of vacuum hose glued to flat rubber washers will have to do.
The pivot bushings and retainer (from CofT40's) are in the middle but the spring is too long - must be shortened to provide tension.
The felt pad is up top, under the square piece of metal near the center of the motor.
At first I thought it was an air cleaner but I'm not exactly sure how these things work.
Seems to me, there has to be a port for fresh air to enter unless somehow the vacuum re-circulates.
Far right, is the chrome escutcheon nut that holds the switch to the dash.
I think all that's missing are the mounting bushings and a star washer.
(new repro knob not shown but does fit well on the switch)
![[Linked Image from img.photobucket.com]](http://img.photobucket.com/albums/v365/88burb/48chevy/48wipermotor.jpg)
![[Linked Image from img.photobucket.com]](http://img.photobucket.com/albums/v365/88burb/48chevy/48wiperswitch.jpg)
