Gidday Fellas,
Does anyone still make these??
If not does anyone have any spare laying around I could buy??
If not what would be a good substitute to use??
So I am talking about a 1928 tourer windscreen part because yesterday I pulled the windscreen off the car including the mounting brackets as I want to replace the glass with a more modern non shattering glass for the RWC when the time comes.
Yes it all came apart easily and there was a little rust in the channels of the windcreen frame but nothing that a little clean up won't fix.... But my problem is that the 4 x metal caps with the hole for the screw to go through that hold/lock the screen down tight once in position were rusted and non useable again....
Any help or advice on where or who has these would be great...
Cheers Grant.
"We're not painting it all fancy"
http://montythe1928chevrolet.blogspot.com.au/
Grant
I think I've got some, I'll have a look and let you know.
Chris
Mine were rusted so as the hole was to big for the screw, so as the head of the screw would pass straight through.
I cleaned them up, used some bakers soldering fluid (zinc chloride 400 g/l), then applied some lead-tin solder with a good old fassioned copper head iron. File to shape and drill a new hole for the screw.
Gidday Fellas,
many thanks for the heads up and offer...
I called by a mates place today and he said he could knock me up a couple of the parts I am wanting, so all is good....
But I am still desperate for a 28" spare rim if anyone in Victoria, Oz is watching
Cheers Grant.
Grant, There is a windshield frame on EBAY right now, Its in Michigan....Might be good for some extras. John
Hi Grant,
Do you want those parts pre rusted, or will you create your own patina. Only joshing.
Cheers
Ray
