I think that your 180 off. If your unsure watch the rocker arms as you turn the motor over. Watch for the #1 intake valve to open, this is letting fuel mixture into cylinder, then the piston comes up squeezing the mixture and making compression, the rotor points to the #1 terminal on the distributor cap and sends spark to the spark plug. After the explosion the piston goes down, then when it comes back up the rocker on the exhaust side moves and opens the exhaust valve letting out burned up stuff. Don
