#240004 04/16/12 08:07 AM
virg912 Offline OP
On my 54 235 eng. (car) where does the hose go and what goes in the hole where there are threads. Hope this is clear...there is a little square thing that has a little pipe and a hole with some threads....Virg
The hose goes to wiper motor....That is a vacuum supply to make the wipers operate
Virg912,
Here's how it goes in my '50 with a '54 235.
[Linked Image from i119.photobucket.com]
Dean 50 - VCCA #44675
The 1953 and 1954 is completely different as the wiper motor is exposed on the front of the firewall under the hood.
virg912 Offline OP
where the round thing with the tube is ..mine is square and has another hole with threads....it is a 54 eng. and in a 50 sedan....
One is the wipers and the other is for the automatic trans.
pete
virg912 Offline OP
no automatic transmission.....I think I found out the other line goes to the auto choke...
On my 1950 with standard trans it only has one and it goes to the wipers. On my 52 one to wipers and one to auto trans,the auto choke has no vac. hose. I think your engine came from a car with auto trans and you need the correct manifold fitting to eliminate that other line.
pete
pete
