#239682 04/12/12 11:41 AM
I have W-18 plugs in my 1926 chevrolet and am wondering if I would be farther ahead to get 3077 plugs. I have seen them brought up a few times. I am told the W-18 plugs are a hotter plug. If the 3077s would help my car run a little cooler I would like to get a set. Any input is greatly appreciated. Thanks!
Hi again Leroy,
You can get Muriatic Acid at Lowe's or Home Depot. I would think most major hardware stores would carry it. BE CAREFUL WITH THIS STUFF! Muriatic Acid is actually Hydrochloric Acid.
http://en.wikipedia.org/wiki/Hydrochloric_acid
Advance Auto Parts carries the Autolite 3077 spark plug. Check the web, there are a number of other places which carry the 3077 (E-Bay, Amazon, etc.)
Happy Motoring,
Dan
Hey Dan, I just got back from town. The hardware store had the acid so I ran in and got it. My question about the plugs though is if they might be another way to help my overheating problem. My neighbor is a farmer and said they used to run W-17 plugs which were a hotter plug and he thinks the 18's are a hotter plug yet. I noticed people talking about the 3077's so was curious if I might be better off switching to them, if they may be a cooler plug. I know it wont completely fix my problem, though maybe it will help? Thanks again!
The use of hot or cold plug will not really affect the engine operating temperature.
A hot plug is used for cars usually driven at slow speeds, and in a lot of stop and go situations, like in city traffic. The plug tip will stay hotter than a cold plug, keeping the tip from fouling at idle or low engine speeds.
A cold plug is used when higher speed driving is the norm, like cruising around on roads with little to no stop and go traffic. The colder tip will prevent pre-ignition (knocking).
The impression I get, from reading the posts on this site, is that the 3077 does a pretty darn good job overall on these 4 bangers.
I also agree with what bobc4 said in the post on overheating:
Stick with it having it running and on the road is fantastic and worth the frustration.
Happy Motoring,
Dan
Go with the 3077. If you need a set I have them available.
devil Agrin
I just bought some Autolite 3077's at NAPA.
