#239713 04/12/12 06:31 PM
jayen Offline OP
Before I road tested my vehicle I had it tuned,adj.tappets,new points, new plugs.
When I decelerate,ie. lift my foot off the gas the engine backfires several times.
It does not happen all the time, but frequently.
Any ideas?
Regards,
John.
did you change the condenser they some times are at fault and cause back fire.
Al
jayen Offline OP
Hi Al,
No I think he thought it was a bit tricky with the electrolock.
I do have one, is there anything tricky about replacing it .
Regards,
John
Hi John,
The idle mixture may be too lean. Try enriching the idle mixture by turning the idle screw in a bit.
Happy Motoring,
Dan
might be a slight vacuum leak
I once had my timing to far advanced and it would do that...
Not really just have to be careful.
Al
If it backfires thru the exhaust system you may have a leak at the connection of the exh. pipe to the manifold.When you decellarate it will draw in a little air (oxygen) and combined with the unburned fuel give you the backfire.
iagree
This is a very common cause of backfire. If there is a manifold leak or exhaust pipe leak close to the valves it will back fire and quite impressively at that!!! bana2
Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety. B.F.
jayen Offline OP
Thanks guys,
I have changed the condenser.
I soaped up the doughnut at the exhaust/manifold connection and noticed there was a small leak, hope this is source of the prob, will test drive in a couple of days.
Thanks,
Regards,
John
jayen Offline OP
Those couple of things seem to have solved problem.
Thanks.
Regards,
John
