Hello everyone----first of all let me thank all of you for all your help on my project---your imput is so very valueable! My newest problem concerns my horn----I removed the horn & bracket to get the valve cover off---after loosening the stuck valve,I replaced the valve cover and horn and bracket!! Now,the horn only "burps" or "hiccups" when you push horn button.I checked power to horn connections---5.75 volts,connections are tight,powers up when you push button---everything seems ok----then nothing but a belching sound that lasts for about a tenth of a second--any thoughts on this will be wonderful,thanks,Jay
