#239415 04/09/12 07:51 PM
Are the rear axle assemblies the same for 27 thru 31? I mean the housing, differential, axles and bearings etc? Thanks Tim
The 1 ton and 1 1/2 ton truck rear ends are not the same '27-'31. The rear brakes are different as well other differences.
I could be wrong but looking through the master parts catalog the 30-32 rear ends are the same but the 29 is different. This is for the 1/2 ton pickup. Maybe others can add to this.
Lee
Someone's opinion of you does not have to become your reality.
The 1/2 ton rear end assemblies are different for each year 1929, 1930, 1931, 1932, 1933. Brakes, length of torque tube and axles are the major differences.
Sorry, forgot to mention its a 1 1/2 ton truck. Tim
Thanks for the correction Chipper. If I had turned one more page in the parts catalog I would have seen the differences.
Thank You, Lee
