Posts: 80 |
On the door lock pillar, there is a lip about 1/4" X 1/4" that looks like it is only filler for the bead along the door skin. How important is that? I'm tempted to moit it.
Pat :eek:
Posts: 80 |
Sorry, by moit I meant omit.
Pat
Posts: 3,163 |
David Entler omits that piece off his wood so you don't have to reskin the door. Not sure what the others do. Joe
Posts: 3,163 |
I talked to Jim Rodman this morning & he also leaves that piece off otherwise you'ld have to uncrimp & recrimp the door shin. You could build that little sliver seperate & set it into the grove with a bead of glue between the 2 pieces of wood & it would be about the same. I put my doors together without & they're very strong, stronger than i thought wood would ever be. Good luck, Joe
