wawuzit Offline OP
Does the REAR leaf spring have a grease fitting in the spring holder towards the FRONT of the car?
there are none on my 38 coupe
wawuzit Offline OP
THANKS
My 37 1/2 ton does have them.
VCCA #45194
From 1934 a rubber encased bushing is used at this location. It is called an inlox bushing.
Steve...My 38 coupe does NOT have a grease fitting on the front spring shackle of the rear spring.
...But the rear shackles of the rear springs DOES have a GREASE FITTING ..pointing inward.....ED
