Posts: 80 |
How do you remove the ignition switch from the dash panel? I don't see any locknut either inside or outside.
Thanks, Pat :confused:
Posts: 3,163 |
The outside ring is a spanner type. Should be pin holes on the side of the bezel for a spanner wrench....Joe
Posts: 80 |
Thanks Joe,
There are holes as you describe. I also recall the type of wrench, half-circle with a pin at on end of it. Are those still commercially available? Or should I try and borrow one from an old dealership? I hate to use punches & vice grips.
Regards, Pat
Doubt that an old dealer will have a spanner wrench. They are occasionally found but making one will likely be your best option. A piece of flat steel, aluminum with thickness equal (or a little less) to the diameter of the hole is best. Cut out a half circle equal to the diameter of the retainer leaving a hooked end to fit into the hole in the retainer. I have used aluminum as it is strong enough but soft enough to not mess up the retainer.
Posts: 80 |
Hi Junkyard Dog!!
Your suggestion worked.
Thanks a million.
Pat
That's great! Ya, the small drift pin method usually works in removing the electrolock bezel. Glad to help out!
