#236855 03/11/12 09:38 PM
Looking for help - Need a good picture of the bracket/clamp that holds the end of the throttle cable sheath as it goes down past the carburetor and then behind the manifold to the bellcrank. I'm going to have to make one since the original is long gone. Any help will be appreciated. Thanks.
efrey(at)verizon(dot)net
Never mind! Found in bottom of box of junk! (Never give up!)Thanks for looking. Ed Frey
