Posts: 165 |
Does a std 31Chevy coupe have a switch on the dome light? Also, is it wired with a ground wire . I'm in the dark ..... Ha ha Stanman
earlychevguy
Also, is it wired with a ground wire The dome light assembly is mounted to wood.....therefore it has to have a ground wire.
Posts: 165 |
What switches the light on? J.D. Give me your 25 cent classroom session on the highly technical aspects of the 31Chevy dome light.. You know... Wire gauge , location, switch or no switch , etc,etc. Thanks in advance Stanman
earlychevguy
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
The dome light has a positive line running up the passenger door post with a slide switch and then on to the center stud on the light socket. The housing has a ground line running to a ground on the body or frame.
Posts: 165 |
Where is the slide switch normally located?
earlychevguy
Where is the slide switch normally located? The dome light has a positive line running up the passenger door post with a slide switch.....
Posts: 283 |
My switch for the dome light is on the pass side center post,It is a slide switch that runs vertical.There is a large bore hole that the wires come thru the ground wire is attached to the metal that covers the wood by one of the nails.It looks like mine has never been touched, so i think it's correct.
Wake up to learn something new everyday.
Posts: 165 |
Thank you all for the dome light seminar . I now feel confident enough to do it the right way the 1st time Stanman
Posts: 825 |
Hi there, just what I was going to ask next, now I know it alllllll ta Peter
never give 100% unless you are giving blood.
