Thank you very much Chevgene,
Hi,...
The FKJ in the mid 40K's and the FAA in the mid 600K's - but which November? 47 or 48? ...
Sorry,
Early on I transposed the 'K' and 'J' which resulted in me thinking November when the J = October.
The 1948 models were in production from 1-12-48 til 12-22-48.
Engine numbers ranged from 1001 -825234.
Seems to be a later marriage.
825234 divided by 12 = 68769 (.5)
68769 times 10 = 687690 through October.
But doesn't add up with two engine plants.
If each plant made about half - an original vehicle wouldn't have an engine number exceeding ~ 412617.
That should be Fleetmaster serial numbers ranged from 1001 through 825234. The car was assembled in The 9th month.
The numbers seem to be in the correct sequence for a car assembled in August.
The ninth month (Sept) = 'I'
And the tenth month (Oct) = 'J'
And your data indicates an 'H'? (8th month = Aug)
Now I'm wondering the VIN is a fake - Below is a link to a picture of the VIN tag.
The tag is front p.door jamb mounted and it sure looks like a 'J' too me.
http://img.photobucket.com/albums/v365/88burb/vin.jpgThe authorities ran both the VIN and engine numbers under Chevy and GMC but nothing unlawful showed up.
As far they are concerned - that is the VIN number for this car.
The date the block was castwill be on the right side of the engine near the distributor.
It is there but I can't see it clearly enough to read.
Sooner or later the front clip is coming off, then I'll have good view.
The window glass will have the date the glass was made and the car would have been assembled in the following month for the most part. Look for the LOF and the date - example 7-48
LOF dates:
The front windshield corners are too cloudy to read the LOF numbers.
From what I can see of them, the logo matches the side glass.
No LOF was found on the rear.
Side glass:
D.wing = 12 - 48
D.door = 1 or I - 47
D.rear = 2 - 48
P.wing = 2 - 48
P.door = ? - 48 (1st is unreadable)
P.rear = 8 - 48
The numbers all display above a number 7, except for the D.wing which display above the letter 'F'
