#235907 03/02/12 12:35 PM
Hi, I have a 1933 Master 3 window rumble seat sport coupe and I have a question about how the back seat cushion is mounted and fastened to the trunk lid? The bottom cushion I know how it mounts, but the back cushion I don't. The wood is good and some has been replaced so that part is good. Thanks for any help you can give me, Larry
Become a Member!
Larry-The original seat frame should have had two tabs on the back of it that fit in slots on the decklid . The bottom of the seat frame should have had tabs that bolt / screw the lower portion of the seat back to the decklid . Your decklid should have those slots and holes-
Are you saying the wood in lid is good or you saying the seat back wood is good or new? The lid should be all steel & the seat back usually has some clips that clip into a slot in the lid...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
