#235725 02/29/12 01:14 PM
stanman Offline OP
Hi guys
Did a standard coupe ever come with dual side mounts ?
earlychevguy
stanman #235735 02/29/12 03:13 PM
As I understand it, not from the factory. The Standard Coupe (3 window) sold for $535, no frills (including no bumpers,$15 extra). For $550 ($565 with bumpers), you could get the Deluxe Coupe, the same car in the Deluxe version, complete with twin sidemounts, cowl lights and stoneguard all installed at factory.
Having said that, of course a dealer could add sidemounts (and new front fenders/brackets), cowl lights and stoneguard at buyer's request to a Standard Coupe, not an easy thing to do, but who knows, perhaps as a sales tactic for end of year inventory.
Gunsmoke #235740 02/29/12 03:54 PM
My '31 five window coupe came with sidemounts. It is Job # 31567.
Sid
6wheel #235752 02/29/12 06:55 PM
stanman Offline OP
So my 31coupe with dual side mount wheels and cowel lights IS considered a deluxe model?
Right?
Stanman
earlychevguy
stanman #235756 02/29/12 07:48 PM
Yes, and most likely came that way direct from factory. There were 20 models of the Chevrolet car in 1931, including roadsters, 3 types of coupes (3 window #31557, 5 window coupe #31567, and 5 window sport coupe #31558), and cabriolets, 2 door coaches, 4 door sedans and phaetons, all of which were also available in a Deluxe version, and some in sport version. Check the '31 Chevy site in the forum list for lots of details.
My '31 Coach is Canadian made. In Canada, Coach's were job #31551 (same as in USA), but I understand the Standard Coach was model 100 and the Deluxe model (AKA Special in Canada)was model 105. This is all probably more than you wanted to know, but every '31 Chev owner should know all it's relatives!!
Gunsmoke #235761 02/29/12 08:19 PM
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
[Linked Image from 1931chevrolet.com]
Gunsmoke #235774 02/29/12 10:28 PM
stanman Offline OP
O.k.
Now that I'm certain that I have a deluxe model after all this time,I have a question about my window garnish.
From what I know ,there should be a V shaped door cap along the lower side of the window opening . That is ,According to Hampton.
I don't have that .
I have a straight window garnish. As if it's a standard model.
What gives?
Stanman
earlychevguy
stanman #235782 02/29/12 11:16 PM
What is the Job Number of your '31 coupe?
stanman #235786 02/29/12 11:37 PM
There has been an assumption that the cars with "Deluxe" exterior (cowl lights, side mount fenders, gravel screens) also had a "Deluxe" interior. The so called "Deluxe" window mouldings had the shallow "V" on the bottom. The doors had double stitched panels. I hate to "burst the bubble". Each body type had window mouldings independent of the exterior. The Standard Coupe (31557) for instance had black moldings (with flat bottom mouldings) and single stitched panels.
Chipper #235789 03/01/12 12:00 AM
stanman Offline OP
My car job # is 31557 .
So does that mean my car was an upgraded standard model?
Because I have dual side mounts , two cowel lights , and straight and flat black window garnish.
I don't have original door panels to see any stitching .
Stanman
earlychevguy
stanman #235793 03/01/12 12:18 AM
Both the Standard Coupe (3W) and the Deluxe Coupe (3W) had same job # 31557. So what you have is a Deluxe Coupe. They called the 5 window version the 5 Window Coupe and 5 Window Deluxe Coupe. They called the same car with a rumble seat in lieu of a trunk the Sport Coupe and Deluxe Sport Coupe. So there were 6 coupe models in all!
You may think yours could be an upgraded Standard Coupe, but technically speaking, you could not order "upgrades" or "Options" from the factory at that time. You ordered a Standard Coupe, or a Deluxe Coupe, that was it. However, as mentioned above, the local dealer could always change the features on a car by simply ordering in the parts necessary to convert a Standard Coupe to equivalent of a Deluxe Coupe, but that was likely not common. Unless you can tell car was upgraded after leaving factory (there could be tell tale signs such as cowl lights not being symmetrical, or sidemount hardware not mounted identically etc),it is likely a factory Deluxe Coupe.
stanman #235794 03/01/12 12:33 AM
Upgraded? I guess you can call it upgraded, or Deluxe or what you want. Chevrolet advertised the Deluxe models in 1931 so I would just call it a Deluxe Coupe. Just be aware that it does not mean that it has an upgraded interior too.
Chipper #235802 03/01/12 04:29 AM
My page gives you US and Canadian model codes:
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/1929to33chev.html
Canadian models:
INDEPENDENCE SERIES A.E. OR INDEPENDENCE UTILITY EXPRESS SERIES L.T.
1931 Model Numbers were: Model Fisher Job
ROADSTER 140
ROADSTER DELIVERY 142
SPORT ROADSTER 146 [RUMBLE-SEAT]
SUPER SPORT ROADSTER 149 [RUMBLE-SEAT]
[LANDAU] PHAETON 150 31571
COACH 100 31551
DE LUXE COACH 105 31551S
5-WINDOW COUPE 160 31567
5-W 5-PASSENGER COUPE 162 31572
5-WINDOW 5-PASS SPRT CPE 164 31558 [RUMBLE SEAT]
3-WDW STNDRD/REGLIER CPE166 31557
CABRIOLET [RUMBLE SEAT] 168 31568
[STANDARD/REGULIER] SEDAN170 31559
TOWN SEDAN 175 31581
SPORT [SPECIAL] SEDAN 176 31569
SEDAN DELIVERY 177 31570
AE ½ TON COMMERCIAL 152
LT 1 ½ TON CHASSIS 112 131” W.B. 30 x 5.00 front tyres / 32 x 6.00 rear
LT 1 ½ TON CHASSIS 114 131” W.B. DUAL WHEELS
LT 1 ½ TON CHASSIS 116 157” W.B. DUAL WHEELS
HS* 1 ½ TON CHASIS 114 131” W.B. SINGLE WHEELS
HS* 1 ½ TON CHASIS 114 131” W.B. DUAL WHEELS?
HS* 2 TON CHASSIS? 119 131” W.B. DUAL WHEELS?
* INDEPENDENCE HEAVY DUTY/EXTRA FORT, WITH “CHEVROLET HEAVY DUTY” AND “MAPLE LEAF” SYMBOL ON RADIATOR BADGE, BASED ON GMC T-17A/B
Chipper #235819 03/01/12 12:06 PM
stanman Offline OP
I've decided that my car will remain a deluxe coupe on the outside with standard interior.
If I don't have the fancy garnish I won't need the extra stitching on the door and the extra row of buttons on the front of the seat. It's purely gingerbread anyway,and should not detract from the overall look of my beautiful 1931 "DELUXE" 3 Window Coupe.
Can anyone tell I'm starting to get excited about reaching the end of this 10year restoration?
The helpful comments I'm able to generate are extremely useful to me in many ways.
I want to thank you all. Hopefully in person some day.
Stan Sweeney.........Stanman
earlychevguy
