Hey, Just several questions,
What kind of cup grease is everyone using? There are so many different kinds grease out there.
Do you use the same kind in all of the cups including the water pump?
And do you use grease instead of heavy oil in the allimite grease fittings??
Several drops of light oil in the generator? Do you use engine oil? Thanks in advance, John
I use regular gun grease in all the chassis fittings like springs and king pins etc.Water pump grease in the water pump as some will find its way into the system so it has to be dissolvable so it won't coat the radiator. Starter and genny get light oil like 10 wt or just use 3n1 type stuff. Trans and rear end use 600 wt or steam cylinder oil. Engine use 20 wt or 10-30 and also use that for the rocker arms and valve train. The valve spring pockets should be about half full of oil, if they are already half full, no more needs to be added if you oil your valve stems regularly.
28 Chevy LO Capitol 1 ton, 28 National 2 dr coach, 71 Chevy Custom Camper 3/4 ton. Also 23 Oldsmobile Economy truck and a 24 Olds sport touring.
Another neat story...was telling an old Chevy man that i would like the find correct grease cup grease..He dug around in his stash and found a can that read(cup grease)
0 olive drab paint Circa WWII by standard oil. ! pint...Works great .looks like grainy white lard
Blue38 it sounds like GM MULTI-PURPOSE LUBRIPLATE.
Steve
Thanks.. Where would I go local to fine water pump grease? Can I find it at Auto Zone, O'Reillys ? Would you have a brand name I could look for?
I have some that I ordered from Lubriplate's internet store
I got my water pump grease at the local Antique F**d parts place.
Thanks for the info..back to the garage to play..in the grease.
