#234637 02/18/12 03:41 AM
I have two questions about the floor boards in a 32 roadster . One. Were they painted when new and second would anyone have a patern for the bottom section ,the one that goes around the shifter ?
Autowood Restoration in Hanna, Indiana has the floor board that you need.
I do not believe the floorboards were painted. A good sealer will help to preserve them. Knowing the cost of shipping to Canada I can understand if you want to make your own. My floorboard WAS the pattern for someone that made them up years ago. If you would like I can trace it out, add some notes and mail it to you. Send me your address in a PM if interested.
Hey thanks for the drawings, Much more different than I though but totaly makeable.I have a clear epoxy sealer that I was going to use on all of the exposed wood then Its (Hammer time).Thanks again .
Your welcome and have fun making the board.
My floor boards are painted black on both sides. I do not have a roadster but figure they are all the same.
The toe and floor boards in my original 1932 Chevrolet Special Sedan are not painted.
Thanks for all the info , I only had the toe board and it was so covered in oil and dirt that I wasnt sure if it was painted or not . I am going to leave the ones that I made unpainted .Thanks again
On making any toe boards..use foam board,its stiff and easily cut with razor knife.. measure your complete opening and lay it out on form board. take a foot square piece and using the gear shift screw down cap cut a circle in the one foot piece.. with E-brake, cut slot in a piece of foam board.Cut out the appoximate area in your floor board foam. put floor board piece in your car and duct tape your small pieces in place. remove from car and transfer to a good grade of exterior plywood. Table or saber saw and VIOLA... a perfect fit.
What a great idea! I have to make a set for my right-hand drive '29 Phaeton -- they're nearly a mirror-image of the US cars, but not quite. This foam board idea will help a lot.
Thanks! thanku carbana
All the Best, Chip
"It's wise to choose a SIX"
rjp Offline
Is the 32 floor board diferant from the31 roadster?
