#23510 04/19/06 01:27 PM
FredW Offline OP
How does the dome light cover/lense remove on the roof of my 1936 Master 4 door? Does it pop off or do I need to twist the outer ring? I am afraid that the plastic lense is very brittle and I do not want to bend and twist any more than I need to.
#23511 04/19/06 02:10 PM
Remove the lens and rim together.Its held on by friction and will pry off.Use a stiff putty knife if you have one and protect the head lining.
#23512 04/20/06 09:55 AM
FredW Offline OP
Thanks....you certainly are a wealth of information.
#23513 04/25/06 10:45 PM
Chevgene,
Is this also the same method for a 35 Std? I've had the same concerns as FredW but hesitate to remove it as it works fine. Would like to clean it though. Thanks......Bill
#23514 04/25/06 10:57 PM
Yes, the same.
