I have a few questions on a 1936 Master transmission.While in first gear I get this skipping whining sound , sometimes in reverse as well. 2nd and 3rd are just fine quiet and smooth.
I was told by a few that its most likely the main shaft bearings and that they would need to be replaced. So last week I got everything preped and pulled the transmission, ordered front and rear shaft bearings ect.. from FS , have my 35-36 manual and began to take it apart. I took the cover off on top to have a look, everything looked pretty good and clean. I continued taking it apart found the Bearings and replaced them with the new ones and then reassembled the trans and put it back in the car.
I thought Iam going to test this thing out before I put everything (Interior ect...) back together. With the car still being on jack stands, started it up put it in first gear and the noise is still there.
It almost sounds like a binding/ skipping noise and it sounds like its comming from the rear of the trans.
So this is where Iam at I still have the noise and now While the car is still on the ground engine off and in any gear the car starts rolling, what did I miss??? also Does anyone have any pictures of the rear trans mount to see if mine is installed correctly? I put it back how I found it and not 100% sure its correct. Can anyone help me out?? I look forward to your input. Thanks,Ken
