#233969 02/11/12 12:38 PM
I have a 1976 Nova subframe on my 38 Chevy and it has a power steering box with some play in it. I read in the service guide an number of steps required to gauge how much torgue can be used to apply to adjustment. Just wondering if all these steps are necessary to adjust out some of the play or can you just give it a little tweak and see what happens??
Thanks for your thoughts on this
Chris
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016
1968 Corvette Roadster 383 CI-425 HP
1938 Business Coupe "personalized"
Wilwood Engineering1955-1957
Use the shop manual and do the adjustments in the proper order.
Do not just turn down the pitman shaft adjusting as some idiots do.
Any man that thinks he is too old to learn something new probably always was
