Posts: 724 |
Is the Coupe domelite (chrome trim and plastic lens assy) exactly the same as the sedan except for the hole for the switch stem on the Coupe? thx..Billu38
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
You didn't say what year. I'm assuming by the handle Billu38 that its a 1938 you are interested in. Book shows the following: 11.925 Dome Lamp (less bulb): 1929-39 Closed .......... (when switch is on the lock pillor) w/lens 4090211 1933-39 Closed, 1940 Jobs 1017-27, Ser. 1200-1500... with switch and lens............4090212 11.928 Rim-Lens-Bulb, Dome Lamp: 1934 Series 600, 1935-36 Jobs 1017-57, Ser. 1200 1937-38 Jobs 1017-87, Ser. 1200 1939-40 Jobs 1017-27, Ser. 1200-1500 Rim with lens ...............4073975 1934 Jobs 551-567-569-570-581, 1935-39 Jobs 1001-9-11-19 Rim with lens ...............4073976 I hope you can make heads or tails out of the above. This was from a 1929-50 parts book. Good luck, Charlie
if the coupe is a Master the switch is on the lamp. if the coupe is a Master Deluxe the switch is on the right pillar behind the door. This applies to the sedans as well.
Posts: 724 |
Sorry, YES it's a 38 Master Coupe..Charlie, I pulled up same info but it doesn't quite answer my question...Gene, I realized the Coupe has a hole for the switch stem, but let me put it a different way...if I take a Master DeLuxe chrome ring and plastic lense and drill a hole in the chrome ring for the stem will I have a Master part?? thx...Billu38
Posts: 1,558 |
 You shouldn't have to say you are sorry. You titled the thread, "1938 Coupe Domelite". Beamer
Billu38, Beamer is right. I missed that when I replied. It is I who should be sorry. Best, Charlie
Posts: 724 |
Not a problem....BUT..I still don't have an answer to my question! thx..Billu38
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Unless someone has drilled a hole in a MD trim piece and fit it to a M dome light they probably won't know for sure. Here is a picture of the dome light in my M coupe. ![[Linked Image from i47.photobucket.com]](http://i47.photobucket.com/albums/f167/Tinys1938/Img_1032.jpg)
Posts: 1,558 |
My 2dr Master Sedan domelight looks exactly the same as Tiny's coupe domelight so apparently they are the same in coupes and sedans. Keep in mind chevgene's comment re the switch location on the Master Deluxe. Beamer
Posts: 56 |
The lenses are the same in all the cars, 1937 and 1938, except the coupe lens has the hole in the rim for the pull switch. I don't think you'll ever see a coupe of these years with a pillar switch either Master of Master Deluxe. At the Flint Anniversary meet, I got points taken off because the judge said there was a nail hanging down out of the domelight lens rim. It really doesn't look like a nail with its pretty little knurled knob on the chrome shaft. Still scored just fine though. BTW if you drill a hole it will be just like factory
RD/B
Posts: 724 |
At's what I was looking for..thanks..Billu38
Posts: 1,558 |
My '38 2 dr Master sedan has a pull switch that looks exactly like Tiny's coupe. I have seen this pull switch in other '38 Master sedans and since my car is pretty much original, I believe that is the way it came from the factory. As Gene noted, the Master Deluxe sedan dome light switch is on the right pillar. Beamer
