Pat S Offline OP
My pull rod is broken at the lever. I'd like a photo or a sketch of the bottom part which goes through the slot in the lever. Measurement too I guess. music
Pat S Offline OP
What I'm looking for is whatever was where the red is looked like.
If I remember right it is just an extension of the rod with flat sides to fit in the latch, it has a hole in it for a cotter key, a washer was used above the key.
Ed
This should be close and dirt cheap too.
Pat-I believe I have that if you haven't found one-You can contact me at desoldcar@aol.com
