Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
1932 transmission synchro-mesh #232335
01/27/12 04:12 PM
01/27/12 04:12 PM
Quebec, Canada
D
duhen Offline OP
duhen  Offline OP
D
Quebec, Canada
When I try to shift to 2nd speed, I have to push very hard on the gear shift lever.
What can cause this?
Thank you
The Filling Station 1929-32
Re: 1932 transmission synchro-mesh [Re: duhen] #232340
01/27/12 04:33 PM
01/27/12 04:33 PM
denver
J
jim_Del Offline
jim_Del  Offline
J
denver
I am also having problem shifting. I disassembled the transmission and reassembled. I believe my adjusments are alright. Question: are parts for the 31, 32 transmissions still available...synchromesh parts in particular.
Re: 1932 transmission synchro-mesh [Re: duhen] #232400
01/28/12 02:09 AM
01/28/12 02:09 AM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
Clutch adjustment can be one cause. If the clutch does not fully release it will shift hard. Does it shift ok when stationary?? Grind when going into second??
Re: 1932 transmission synchro-mesh [Re: jim_Del] #232402
01/28/12 02:44 AM
01/28/12 02:44 AM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
The 1931 was a completly different non- syncro trans.
Try double clutching when down shifting to 2nd. If that helps then you know the problem is in the syncro. part of the transmission.
Chevgene
Re: 1932 transmission synchro-mesh [Re: m006840] #232412
01/28/12 04:08 AM
01/28/12 04:08 AM
denver
J
jim_Del Offline
jim_Del  Offline
J
denver
Does not shift well even when stationary. Double shifting doesn't work either. Jim
Re: 1932 transmission synchro-mesh [Re: jim_Del] #232420
01/28/12 06:49 AM
01/28/12 06:49 AM
Australia
jack39rdstr Offline
jack39rdstr  Offline
Australia
I would check for wear in the end of the clutch fork and the clutch actuating plate, as the hole in the plate can become oval, and you may be losing the travel to release the clutch plate. Always a good idea to check the easy things first before taking the gearbox out.
JACK
Re: 1932 transmission synchro-mesh [Re: jack39rdstr] #232424
01/28/12 07:44 AM
01/28/12 07:44 AM
Vancouver, WA
AntiqueMechanic Offline
ChatMaster - 9,000
Vancouver, WA
I had a problem with my 33 (basically the same transmission) and discovered that the retaining cap that holds the shift lever down was loose. Several turns and I was back in business.
devil Agrin
Member Chat Group - Non-Geographical Region
Re: 1932 transmission synchro-mesh [Re: duhen] #232435
01/28/12 02:02 PM
01/28/12 02:02 PM
Niceville Fl. (panhandle)
6
63_SWC Offline
63_SWC  Offline
You should be able to determine if it is a clutch drag problem or not by shifting it into a non-synchro gear ( ie first or rev.)
If it shifts easily into 1st and rev without any gear noise I would rule out any clutch drag problem for now.
Larry.
Re: 1932 transmission synchro-mesh [Re: m006840] #232438
01/28/12 02:31 PM
01/28/12 02:31 PM
Quebec, Canada
D
duhen Offline OP
duhen  Offline OP
D
Quebec, Canada
As others stated, it don`t seem to be a clutch problem because it's easy to shift in first and in rev. And yes it's hard to shift in 2nd even when stationnary. I don't hear any grind noise, it's just pretty hard to push the lever in place.
Re: 1932 transmission synchro-mesh [Re: duhen] #232446
01/28/12 03:44 PM
01/28/12 03:44 PM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
First thing I would check is the slider in the top of the transmission cover to make sure it slides easily. There are two of them one for first-reverse and another for second-third. They are attached to the shifting forks which actually move the gears into place.
Re: 1932 transmission synchro-mesh [Re: Chipper] #232454
01/28/12 06:32 PM
01/28/12 06:32 PM
Quebec, Canada
D
duhen Offline OP
duhen  Offline OP
D
Quebec, Canada
I already verified this, both are working correctly
Re: 1932 transmission synchro-mesh [Re: duhen] #232469
01/28/12 09:14 PM
01/28/12 09:14 PM
merrimack nh
m006840 Offline
m006840  Offline
merrimack nh
If the shift rails and forks work ok when stationary and the clutch is releasing then chances are the problem is in the lever and tower. I would remove the shift lever assy and inspect it.
Re: 1932 transmission synchro-mesh [Re: duhen] #232546
01/29/12 05:15 AM
01/29/12 05:15 AM
Chipper Offline
Chipper  Offline
Is the die-cast retainer on the top of the transmission cracked or broken? Or interlock worn on one side more than the other? Do both yokes fit the same on the shafts? If there is wear on the shafts or in the yokes then the yoke may tilt and bind on the shaft.
You can also try shifting the gears with the transmission top removed to observe the movement of gears. Also move the shift lever with the top removed from the transmission to see if there is any binding on that part. Once you isolate the problem then it can be fixed.
Re: 1932 transmission synchro-mesh [Re: Chipper] #232575
01/29/12 04:46 PM
01/29/12 04:46 PM
Quebec, Canada
D
duhen Offline OP
duhen  Offline OP
D
Quebec, Canada
I verified all of this with no luck.
The problem seem to come from inside of the transmission.
The, according to the manual "second and third speed clutch" seem to have problem sliding. May the rear synchronizing drum spring can be the cause?
Re: 1932 transmission synchro-mesh [Re: duhen] #232583
01/29/12 05:42 PM
01/29/12 05:42 PM
Chipper Offline
Chipper  Offline
If it is in the transmission, then it must be the shaft/slider fit. What happens when you manually slide the second/third slider? I should move freely by hand and even by gravity if you tip the transmission case. If it doesn't move easily then you will need to remove the shaft and gears to determine the problem. That is unless by moving the slider you discover a "hard" spot or some small metal contamination between gears and shaft that can be removed.
Re: 1932 transmission synchro-mesh [Re: Chipper] #232603
01/29/12 09:34 PM
01/29/12 09:34 PM
Quebec, Canada
D
duhen Offline OP
duhen  Offline OP
D
Quebec, Canada
Thank you, I will check that
Moderated by  32confederate, d2d2
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
3 registered members (nhinchas, Rustoholic, pushrod), 7 guests, and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,518
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
