#231834 01/23/12 10:56 AM
p.k. Offline OP
On my 66 corvette s.b.I believe it came with AC 44 spark plugs from the factory.
Now that they are not available any more does anyone(know)
the correct replacement ? AC-43,AC-45,AC-46 ? Let me know
what you think before I spend my money... patriot
p.k.
1956 BEL AIR 2 DOOR HARDTOP
Wilwood Engineering1955-1957
p.k. #231850 01/23/12 01:14 PM
Online Happy
The AC 43 is a colder plug, AC 45 a hotter plug (used on may Chevy V-8s). Of course AC 46 is even hotter.
Chipper #231853 01/23/12 01:41 PM
p.k. Offline OP
Witch would be the correct replacement plug ?
p.k.
p.k. #231859 01/23/12 01:51 PM
Online Happy
You will need to decide which is best. If the engine starts fine and the current plugs have a light tan color then one step up or down should be okay. If there is any evidence of dark buildup on the electrodes a hotter plug would be better.
Chipper #231870 01/23/12 02:48 PM
p.k. Offline OP
Thanks Chipper.... beermugs
p.k.
p.k. #231873 01/23/12 03:08 PM
P.U. Guy #231879 01/23/12 03:51 PM
There is no"correct" spark plug for any car. The factory used an "in-between" heat range plug. The correct heat range would depend on youtr driving.....and the factory plug satisfied the majority of drivers. I would go with the 45 unless you do a lot of (80 MPH) high speed driving.
I would also suggest the R or resistor plug for a Corvette. Will prevent ignition noise in the radio. I use R45 plugs in all my cars including the 6 volt ones and have no problems.
Chev Nut #231969 01/24/12 10:05 AM
p.k. Offline OP
After spending a day on the computer and searching many corvette part sites and auto parts stores napa,autozone and O'reillys.It seams that the AC R43 is like Gean said,it's a plug for open driving (witch is what I do ). The AC R45 is more for city stop and go type of driving. I have decided to go with the AC R43 for my type of driving, My closes big town being 80 miles each way. After a 1000 miles or so I'll pull a plug or two and see what's goin on. THANKS FOR YOUR THOUGHS...
patriot driving
p.k.
